- Nov 21, 2010
- 1,602
I try not to be long winded. first we are NOT a production shop. Stupid me does not refuse whatever work. A customer that has price shopped around finding to be outrageously
out of his budget. The job high tech expensive cribbage boards inlaid all brass'ed up owners name lasered name plates etc. For a start, the job is 2,000 cribbage pins in being
1/4 inch yellow brass, white brass, alum. and copper. The operations are using a parting tool to mark the lenght part three rings .022 deep and a 5 degree taper to the last ring.
(I machined a test gauge for the length rings and taper, then draw file the point round, then part off. Rechuck the pin and draw file the top (break the edge round), then to the
buffer, using a rubber hose to hold it. I punched the time clock, I cant get better than around 9 minutes each, and to be competitive i said maybe around a dollar each, and doing
the math by 60min in an hour that aint going to work. What I did; 3 or 4 jaw chuck out of question, machined a so called collet holder zeroed in a 4jaw with 4 set screws for the rod.
The smallest lathe we have is a long bed 9A SB. Now, I exactly know how to spit these out, but I'm not about to buy a $5000 B&S screw machine or a $500 Box tool.
I am not running lead screw or gear box either. Ok problem is this lathe is now dedicated, most used (other ones are too big) I dont want to change the set up.
Next problem Is after doing about six I gotta sit down my back can't take it. So I'm out of ideas, even made a form tool to cut the 3 rings that don't work (too soft) and I cant
taper turn no more that .002 - also there's no way with the copper just touch it and it goes spaghetti. Last problem is customer works with my son state union carpenter so its
more like a favor. Lots of brilliant people here that may have ideas to save time?? And I have machined about 200 pieces exact to the prints.
thanks sam
I imagine a 5 degree taper female cutter in the tail stock then life would be easy. New PC so sorry no pic it wont except my camara dont know why?
thanks sam
