- Feb 2, 2013
- 3,627
before painting the bike, i figured i would make the frame modification devises the priority
my plan is to add a stiffening leg to the frame, that would double as a fuel tank mount since i will not be using the stock fuel tank
here's the tank
designed for a 125cc pit bike, the inexpensive tank holds 1 gallon.
hopefully that will translate to about 40 or 50 miles of ride time before refueling
[the stock tank was 1.6 gallons- the stock CT90 was supposed to get somewhere in the neighborhood of 100 miles per gallon
i cannot substantiate that, i have never rode one that long.]
the brackets to attach the stiffener to the frame have been created in PLA plastic.
i also designed and printed the standoffs for the fuel tank.
i'll manually reproduce the printed part on the lathe and milling machine as follows:
today i worked on the rear fuel tank standoff .
i made a 3d printed copy, but i found out my estimated length was too long
after finding the length that was going to work, i went to the task of creating a copy
the first step was to turn a 35mm x 200mm piece of scrap 303, into a 28mm x 70mm piece of 303.
i further reduced a 50mm section to 25mm
then bored the 25mm end to a wall thickness of .110"
the standoff was then drilled to 17/64 , ready for a M8x1.25 tapping !
i put he standoff into a 25mm 5C collet and held it in a vertical fixture, in the vise of my Bridgeport
i reduced the rod to a rectangle 15mm x 24mm
after hitting both marks, i remounted the standoff in the 1236 lathe and knocked off the corners off the 15x24 rectangle
to match the radii of the tank mounting bore better
i remounted the support in the vise, pinched with v-blocks to relieve the convex section of the standoff to be welded to the stiffening leg
here is a picture of the standoff next to the 3d replicant
here is the fitted rectangular end, and the 3D printed concept that the standoff was modeled after
the metal copy fits the
and the test fit
in the next act,
i'll be tackling the front fuel tank standoff and welding it up!
Stay Tuned!!!
here's the tank
and the test fit
in the next act,
Stay Tuned!!!
