- May 26, 2015
- 773
Well, from what I can see in the two photos, there are only two things keeping you from selling it as it was originally sold (sans motor). One is that it doesn't have the 2-step motor pulley and 2-step countershaft pulley. And two, the back gear lever belongs on the other end of the shaft. Where it is now, I think that if you try to mount the gear guard. it won't close fully.
Yes your correct on both counts. The back gear is installed and both the belt cover and gear cover does open and close properly. I wanted it on the left side because I'm going to mount the motor on the right side of the counterbalance and have moved the pulley to the right side. Trying to keep the lathes footprint smaller. The pulleys can be bought by it's new owner it they so desire.
