- May 26, 2015
- 773
When I adjust the gear train I use a strip of paper where the two gear mesh and tighten it down. Only play I see and hear is the forward/reverse gears. They wobble a bit on the holding bolts but is still acceptable from a noise standpoint. My lather really runs quite including expected noise from the back gear which I bought new.!
Also I have no slop in either the cross slide or compound slide. Gibb screw are set well.
