- Nov 25, 2014
- 20
I'm attempting to make new dies for my tube roller, similar to the one pictured but with a flat bottom (for 2" square tubing). My challenge (I probably should say my FIRST challenge) is holding the blank and still be able to turn the bearing pocket (so I can chuck it internally later).
In other words, my 3" chuck isn't capable of holding my 4" workpiece. I have a backplate and can drill centers in the part (I'll figure out a way to drive it once it's between centers). My idea is to bore most of the bearing pocket so I can use my chuck jaws to hold it from inside the pocket, then I'll finish the profile. I'll have to do this on both sides of the roller die, obviously.
I am closely watching ebay for an inexpensive chuck large enough to hold these 4" diameter chunks, but for now I want to make chips!
I don't think I have to explain my reasoning for spending twice as much $$ for the lathe and steel as a set of new dies. After all, I will still have my lathe for future projects! (Forgive me, I'm used to explaining my logic to my wife)
Any suggestions welcome, and please pardon me if I posted in the wrong place... Thanks in advance!
