- Oct 4, 2011
- 727
I just picked up two larger steel map cases. They measure outside 44" deep and 54" wide. The two stacked are 35" with a total of 10 draws each about 2" deep. The inside usable space is a little smaller. I put 50lbs of weight in a draw and it still slides easy so it should be good for tools. My shop is small so not a lot of need for roll around tool boxes the three I have are plenty. My plan is to do one draw for all my wrenches, sockets, drivers, and pliers, Then one for all my screwdrivers, punches ect.. I am going to wait till after Christmas to make the boards to organize the tools in each draw. I figured by then I will have everything moved to where I want it.
I have two more smaller ones that will be the base for my new electronics bench. Should hold most all of my components.
Jeff
Jeff
