- Jan 11, 2013
- 1,821
sent you pm hope it gets trough regards jack
Hey Jack
Let me know if you got the info and can open it...
Bernie
Oh Schor- I didn't know you hadn't milled before ... That's a different story! I will write you a different kind of trouble shooting guide tomorrow. How exciting!
Starting with aluminum is a good idea. Shallow cut, high speed. Are you using an SFM chart yet? What type of endmill?
Bernie
So I have the new drawbar in place, lots more threads grabbing the holders. Works better, but was still not right in my mind. But then I have never milled before so what do I know.
I found that my gibs were not tight enough so I set them up again, this made it much better. But I still notice that the quill has some play vertically, so I started using the quill lock once I set my depth of cut.
I still think I don't have some things right because I am getting so much chatter and vibration. I know its only a benchtop and maybe my feed or rpm is not right, or the cutters are not the best or whatever. Need to keep plugging away and figure it out.
I was working with mild steel because I have a project in mind, but I think I'll switch to aluminium and just play around to get a feel for things.
