- Nov 28, 2016
- 2,360
Ok, here goes...
To remove the compound rest on mine (yours may be the same), look on the side of the carriage... there should be a set screw on each side...
Back those set screws out all the way and the compound should lift out of the hole... there is a dovetail on the bottom of the compound that the set screws seat into, holding it in.
I have the compound off mine... it is in good condition, just filthy... I should have the gib, screw, nut, and handwheel floating around here somewhere.
It looks pretty rough, but is just nasty... I'll drop it in the parts cleaner tank and see how clean I can get it.
The follow rest...
It should fit an 11 inch Logan...it is in good condition, but also needs cleaning.
The collet adapter...
The big end of the taper measures 1.625, the small end measures 1.495, and the taper is 1.940 long. It is stamped '3005023' and 'Sutton SH' on the end. A 5c collet fits the ID.
I'm not sure how to determine whether it is the correct adapter for your lathe... maybe the dimensions will help... if you need any more information, I'll do what I can to help with it.
The model number of my Logan is a 1957T... serial number 88056 if that helps...
-Bear
The follow rest...
-Bear
