- Feb 25, 2021
- 3,129
I haven't purchased steel yet for the rails and bridge. I used L/600. I found references for L/450, L/600 and L/800 IIRC. I compared that against a 5x safety factor. Pretty similar overall dimensions, I'm running just a bit smaller. The side rails are supported by 4 posts, so the side rail span is only ~ 13'. I assume with a low overhead you're still using top running rails.How did you size the bridge rail? What sort of safety factor did you look at?
At ~400lbs plus rigging, I'm going to try just dragging the bridge from the hook, but I'll add a cross pipe and drive chain if needed.
