We pressed a shaft out of it's gear and got the pressure on the shaft up to a little over 314 tons with the new press. I am imPRESSed with the results. The gauge in the photo is showing the pressure when the gear finally broke loose and was moving off of the shaft but it broke loose at 8000 lbs.Since the span is so wide the tonnage will have to be fairly low to prevent bending the 2 C-beams with too much juice. Might weld in some flat plate to stiffen up the base and then the tonnage goes back up to 50 or 100 tons easily, buy thay must be continuously welded from one end to the other on top and bottom of both sides.
Bob
