- Dec 18, 2019
- 6,538
Managed to drill two bad holes into my lathe base. They are M6 and they just are in the wrong place. I am trying to mount my stepper motor on to my lathe. I don't have clear access to drill the holes which caused issues. One hole broke through the outer edge of the casting when tapped. The drilled hole was too close to the edge. The other is not straight and offset from the slot. (Lower than the slot and going downhill!) Both holes are on the bottom. The breakthrough is on the bottom left, and the total eff up is on the bottom right.
So can I use my TIG to fill the holes and start over again? Can I use silicon bronze? Or will I be generating more problems for myself? In any case, I will move the darn cabinet out of the way so I have a fighting chance to drill things straight. Really irks me to have messed up this last hole. I used the stepper mounting plate as a drill guide and still messed up the hole. Going to be hard bringing down the TIG welder into the basement, but I can't think of any other good way to plug the holes. If you can think of a better way to save this, let me know.
