- Sep 30, 2012
- 521
I need to cut a slot in this bracket with a slotting cutter, need to know what feed and speed you would recommend. I don't use a slotting cutter very often.
Material : cast bronze
Cutter: 3"X3/32" - 32 tooth
Slot is about 3/8" deep
I have to make two passes to get the slot wide enough. Would you make the cut full depth or multiple passes.
Also need to know the rpm and feed rate.
Thanks
Thanks
