you could always try pushing them out with grease. make an adapter and put a zerk fitting in, and pressurize the bearing chamber. point it away.. I would take a plastic soup container and put it in there so when it comes out, it's all contained.
Also heat is your friend... even a hot air gun can help before you do the grease.
