I purchased a used Royal live center from Lost Creek Machine. The exterior surfaces are in great condition, almost as if it wasn't used very much but when I turn the center by hand it seems to me that it takes a good bit of effort to rotate. There is no roughness or grittiness when rotating. I really think that it just sat for a very long time and the grease has dried up. There is a SHCS on the end of the taper. I removed it and sprayed some light oil in the back of it, re-installed the SHCS and put it in the headstock of my lathe and spun it up to 1,000 rpm. At first it required a good grip to hold onto the center but after 30 seconds or so it loosened up to the point that the resistance to rotate it feels similar to my other live centers. Although it feels like I brought it back to life, I know that the oil I put in there is not adequate lubrication for the bearings and the center did start to get a little warm.
Can anyone tell me how to take this apart or can give me an idea on how it should come apart? When I remove the SHCS from the end of the tapered end there is another 5/32 SHCS down the bore at the back of the body. I thought about loosening it but then I figured I had better post here first and see if anyone knew how to disassemble it.
I looked on Royal's website and can't find any info on it. There is no part# on the body so no way to look it up. I doubt if I call up Royal they would want to give me the time of day on how to disassemble it. I searched this forum and youtube and all I found was a video from Randy Richards but the center he disassembled was not built the same.
I am no expert when it comes to live centers and I have only ever owned a few chinese knock-offs and they seem to turn easily without much effort at all but if the light oil loosened it up I would think that it needs servicing. Maybe I am wrong and higher end centers require more resistance because they are expected to deflect less?
Here is whats etched on the body:
Super-Tri Bearing Live Center
Royal Products, Hauppauge, NY
Made in USA 3MT
Made in USA 3MT
