- Nov 27, 2012
- 7,862
Yes it cuts "pretty well" once started, just a devil to start. I have tried to open the split die as much as possible which helps. Using the technique you are suggesting I can get the threads made, I am just looking for suggestions to make it easier. I am currently beveling the ends as best I can and that is the only way I can get the threads started.
I see, then yeah, as the others suggested & like you are doing, beveling the ends is pretty much all you can do I guess. Bezel them more if needed, like a longer taper. Make your rods longer to account for this so you can grind/cut off that longer bevel. And cutting fluid is your friend.
Curious, how are you holding the rod & die, pretty securely?
Gotta make friends with a hobby machinist! That's what I did before I got into this hobby, but the best I could do was a friend of a machinist.
Too bad you weren't closer, I'd help you out. But sounds like this is not a one time thing?
