- Jan 1, 2020
- 129
I refurbish pre-war hand planes as a hobby and occasionally need to replace the posts for the wooden knob and tote/handle. The posts have #12-20 threads on the ends. When I look up the Major diameter in the tables for the #12 it says it is 0.216”. I have tried different sizes of rod stock and it seems it is either too thick and difficult to cut the thread (using a #12-20 die) or too thin and wants to pull out of the female thread in the plane body. I assume the ideal rod material would be 0.216” in diameter. I have tried rod material from McMaster-Carr, (tight-tolerance multipurpose 01 tool steel rod) 0.2120 and 0.2188 since they don’t sell 0.216. The 0.2188 is REALLY hard to get the threads on but will fit once completed. Interestingly the 0.212 also seems hard to get the threads started, but when completed fit well enough. Rod material less than 0.2120 produces a less satisfactory fit. I have tried to bevel the ends of the rods using my grinder to enable the die to grab with some success, but it still seems difficult to get the threads started. So… if the major diameter for the #12 is 0.216 why is it still difficult to start the threads on a 0.212 rod? I assume it would be even more difficult to use a 0.216 diameter rod, even if I wanted to try it I can’t seem to find any to buy. Any suggestions on the size of rod, thread cutting technique (mainly how to get the thread started) that would make things easier?
Thanks for the help.
I am a woodworker not a machinist so please excuse my ignorance.
