Need a small part done
JimW816
Nov 30, 2017
11
I need to have a small part done. If someone can help me please get in touch with me . Please see attached drawing. Thanks
  • headshell.pdf
Got a pic ? , no room in iBooks for it,
Thanks for replying. Here is the jpg. Let me know if you are not able to see. I can change M3 to #8 screw if you need to. I also can make thread myself in order to save your time.
Is this what you are looking for? Or is it dished out like a bowl?
And, I don't know if I can make it (need to think on it) - I was just trying to draw it!
I know very little about Sketchup. Here is what I did to combine 3D with 2D. I can change things to fit your tooling and machine if necessary. Thank you!
Yes what's with the "8" dimension up top next to the "13", it only shows in the one view
M
Also be careful, it is first angle projection and not third.
I didn't notice the dashed lines so I modeled it upside down the first time. the 1mm dim is not right as is the side view not depicted correctly.
This is what I came up with.
