- Nov 22, 2022
- 383
Looks like the shaft on a yankee screwdriver, Great analogy for it! This lathe was on a navy ship, It has been on CL for over a year, He used to have a pic of an Anchor and USN stamped near the ways at the end of the bed. I had never seen anything like this attachment before and wondered if anyone else had.Never seen one before. Looks like the shaft on a yankee screwdriver. Some sort of rapid drive. Two different helices, so two different speeds. Can't tell if it drives the carraige or vice versa. Can you get more detail?
I don't know that I agree, There are 2 levers just above them and on the left side that seem to be associated with the device. My first real lathe was a Southbend 13 single tumbler that is almost identical to this lathe and mine did not have those levers, Also, Why would weight be needed there?they are weight.. that's all.
But they are for transversing back and forth.. your typical caged (baitcasting) fishing reel has that , many winches have that to equalize the line back in across the sheave. Those appear to be cut, since they don't have the wrap around area, they just end.
those levers were made for that hack up... those mounting holes are where the taper jig would attach. Someone simply made and used that for some other purpose. I'm guessing that this helped tame some chatter, or looseness in the gib plate at the back... the chatter would be helped with more mass.I don't know that I agree, There are 2 levers just above them and on the left side that seem to be associated with the device. My first real lathe was a Southbend 13 single tumbler that is almost identical to this lathe and mine did not have those levers, Also, Why would weight be needed there?
Ah, that too, a "levelwind". Wish my air hose reel had one.But they are for transversing back and forth.. your typical caged (baitcasting) fishing reel has that , many winches have that to equalize the line back in across the sheave. Those appear to be cut, since they don't have the wrap around area, they just end.
