- Mar 26, 2018
- 8,408
It's getting to be lots of fun at this point.@Janderso, I'm hooked on this idea. Very eager to see how this works out for you.
I want to be able to slide the table up and back as needed. Maybe 3/8" or so.
I'm thinking of using stout sheet metal. Basically, the table and supports are a contained unit.
The trick is attaching the aluminum to the 1" square tubing I'm using for the side supports.
The sheet metal I'm going to use is 3/16". Pretty stout.
If you guys have some ideas on attaching the aluminum plates to the 1" risers that would be great.
I choke when it comes to creativity.
I was thinking of drilling and tapping 1/4 -20 in the aluminum sides, drilling clearance holes in the 1" tubing. How in the heck am I going to tighten the nuts? =slowly.
The 3/16" plate will be under the 1" tube. I'll weld it.
