MY SHOP AND HOME
Brain Coral
Jul 26, 2013
584
Hello all,
I built my shop/ home 4 years ago and thought that I would share some pics of the process and then some present day inside pics.
I was very fortunate to have found a beautiful country lot just 12 minutes from my home city. Lots of nature and quiet, but not too far from where I do most of my work. I am a self-employed carpenter and have been learning machining over the last 3 years and am thoroughly enjoying it.
I began by finding an artist's conception that I liked on E-plans and with two known dimensions, I increased the size, determined the shop ceiling height and then built a scale model out of architectural board to make sure that the roof pitch, dormers, etc. all looked proportionate to each other.
Once I had that to my satisfaction, I drew up a set of plans and submitted them for approval.
I had to cut a great number of trees to begin with and worked hard cutting and burning for a week before the excavation could begin. I hired a local fellow to do my excavating work. He's real good with his "shovel" and could likely scratch a dog's back with it without hurting it.;)
Clearing the land, piling the topsoil and putting the driveway in...
The hole before footings...
I formed and poured the footings myself and then installed and poured the "ICF" (insulated concrete foundation)
Frost wall backfilled and slab poured...
I'll post this for now, as I'm sure that I must be at my limit for pics...
Brian :)
Back again with more pics....
I framed the shop walls with 10' studs, achieving a finished shop ceiling height of around 10'6". Here's the shop walls framed up and ready for the second floor system...
That's me standing on the floor joists. Haha.... I just noticed that my tucked in shirt billowing out makes it look like I have a big belly... :) These joists were clear span from front to back, eliminating any beams or posts in the shop...
Back and side walls framed up and girder trusses going in...
Rear trusses installed and sheeted and the front trusses going in...
I worked lots of late nights by Halogen work lights to get it closed in for the winter...
Brian :)
Ok, back again with some present day pics of the inside of my shop. I combine woodworking with machining in the same space, which isn't ideal, but I have covers for all of the metal working machinery and carefully cover them before starting up my saw, etc.
Here's some pics of the machinery...
Colchester Master lathe and Elliott 10M shaper and Craftex 7"x12" CX103 bandsaw ...
Rambaudi MS2 milling machine...
My woodworking bench being overrun by that insidious disease that seems to happen to all horizontal surfaces in my shop :panic:
Some of my wooden molding planes...
General International 15" planer and Craftex CX400 dust collector...
Shop built router table...
Clamp rack...
There's a Craftex 8" jointer in there somewhere.... as you can see, I didn't clean up the shop for the pics. This is the real world for me with lots of projects on the go and jobs coming in and out all the time. I certainly could use some shelving and better organization. In time... maybe... ;)
Cheers.... :)
Brian
Awesome!! I love shop/home/garage building threads. Looks like you did a nice job. Congrats....
That's not a man cave, that's a man estate! Very cool...
Ray
Thanks fellas.... It's just the right square footage for living space above and is easy to keep neat and tidy... unlike my shop.... and my girlfriend appreciates that.... ;)
Here's a pic of some detail on the front door roof brackets. I like Crafstman details...
Brian :)
Very nice Brian, fine work! How do you heat-cool the shop ?
David
Brian, I love your home/workshop, and am not envious in the slightest! :biggrin: (I often wondered what this green grin smiley is for)
I was self employed in property renovation for 35 yrs and had my shop attached to my house, keeps the overheads down, way better than renting a separate unit.
Bernard
just as one would expect from a craftsman like yourself. fine job.
