- Aug 6, 2015
- 3,910
Figured I would update here... so in this thread I shared that I could not make the radius cut in this little lathe on a 5/8" stock... the tool would dig into the material because the lathe was not rigid enough...
Turns out that the problem, as most of the time with my projects, was the nut behind the wheel... It was user error all along.
The carriage was not tighten correctly against the bed... way too loose...
So I tighten everything and guess what!?
Then I went and got the same cutting tool I used before... the one on the left side in this photo...
And sure enough... worked without issues...
I know it shows shatter in that photo... that was me as well... I started to play with the height of the tool and took another pass... I should have taken a photo before, but anyway, just a quick pass of emery cloth and take a look...
I know that I have said many times that if I find a small Atlas lathe, I will sell this one. Simply because of looks. I just love how the small Atlas/Craftsman, South Bend, Logan looks... But this little lathe has grown on me... I might just stop looking for that Atlas/Logan...
