I was fortunate to get a MT2 shanked Reamer from Machine Tom. I want to use it as a basis for a MT2 live center based on the design by E.T. Wesbury, and as written up by Mikey at http://mikesworkshop.weebly.com/revolving-centres.html
My question: As I have to cut the tail off the taper to fit my 7x14 tailstock, and cut the reamer part off, if I can scratch the shaft and taper with a file, I can cut it on my 4x6 bandsaw, right?
I know I can turn a new MT2 taper for this project, done that before. I plan on turning the shaft part of the reamer to fit a collet for use on the mill after removing it from the taper. I like to repurpose old tools...:thinking:
I could also cut the tool up with an angle grinder or Dremel, done that before also.
Just want to use the 4x6 band saw, but don't want to rip the teeth off my only useable blade on a holiday...
Happy Thanksgiving!
Chuck in E. TN
Happy Thanksgiving!
Chuck in E. TN
