    Dismiss Notice
Moving Heavy Machines By Yourself.
Discussion in 'MACHINE PICKUPS & RIGGERS AVAILABLE & NEEDED' started by woodtickgreg, Jan 2, 2017.
  1. woodtickgreg
    woodtickgreg United States Active User Active Member
    320
    83
    City:
    Eastpointe
    State:
    Michigan
    -Return to Top-
    This is how I moved a piece of a heavy machine (a knee mill) into my basement safely and by myself, This method could be used for many other types of machines. But first I will show you the most important part of the whole method and I built it on the cheap too! A receiver mounted 12v off road winch and the mount. Just build the mount, or by one if you don't have access to a welder and the materials and tools to do it your self. All heavy wall steel and an 8" heavy channel for the base. 2" x 1/4" square tube for the receiver mount. I built this winch mount to move this piece of equipment but I will use it for other things as well now.
    Here's a few pics of the winch mount build.
    Started with bending some heavy wall tubing for the ends to use as protectors and carrying handles. They are 3 pieces, sleeved and welded together. I then ground them smooth with a 4" grinder and sanding pad.
    most of the parts except the channel for the base.
    All welded up and ready for paint. You could powder coat it too but I did it on the cheap. I salvaged all of the materials.
    View from the rear
    It fits my truck nice, clearance all around.
    And I can even open the tailgate with the winch on the truck. When I don't need the winch I can remove it in a few seconds and store it in the garage out of the weather.
    All painted up.
    And with the winch installed. It's heavy but I can pick it up by the handles and carry it by myself and remove and install it. It would be really easy with a helper.
    It's just a harbor freight 12,000 lb winch. Got decent reviews in the off road mags, best bargain in winching.
    I wouldn't leave it out in the weather, but that's another purpose of the removable mount. Plus if you have a trailer multiple mounts could be placed on the trailer easy. I got it on a black Friday sale for $279, they are on sale all the time for $299. I will use this winch for other things, like loading logs on a trailer, etc.
    And here is a you tube video that shows the whole operation and set up. It's 22 minutes long but you just might get some good ideas from this. It shows some heavy angle iron castor mounts I made and bolted them to the machine to make moving it easy. And how I got it off the trailer by myself as well.
    richl, dlane, woochucker and 12 others like this.
  2. jpfabricator
    jpfabricator United States Active User H-M Supporter-Premium
    605
    113
    City:
    Henderson
    State:
    Texas
    -Return to Top-
    Nice Burke, and nice rigging/moving job also.
    Sent from somwhere in east Texas by Jake!
    woodtickgreg likes this.
  3. FOMOGO
    FOMOGO Puerto Rico Active User H-M Supporter-Premium
    987
    113
    Colorado
    City:
    Steamboat Springs
    State:
    Colorado
    -Return to Top-
    Nice job on the winch mount, and congrats on the mill score. I have a similar 12k winch, and made up a 3 position mounting system for the 14k trailer and have used it a lot. Very handy thing to have. Cheers, Mike
  4. silence dogood
    silence dogood United States Active User H-M Supporter-Premium
    134
    43
    City:
    pendleton
    State:
    Oregon
    -Return to Top-
    Adding those protectors was a great idea.
  5. woodtickgreg
    320
    83
    City:
    Eastpointe
    State:
    Michigan
    -Return to Top-
    Makes it really easy to carry and slide into the receiver too!
  6. middle.road
    middle.road Active User Active Member
    217
    43
    City:
    Maryville
    State:
    Tennessee
    -Return to Top-
    Very nice Job!
    Need one of those for my 12,000lb Ramsey...
  7. 8675309
    8675309 United States Iron Registered Member
    9
    3
    City:
    Stormville
    State:
    New York
    -Return to Top-
    Nicely done. Thanks for the video.
  8. dlane
    dlane Active User H-M Supporter-Premium
    499
    83
    Lake oroville
    City:
    Oroville
    State:
    California
    -Return to Top-
    Nice job on the winch mount , shop looks nice too I like the overhead crane
  9. woodtickgreg
    320
    83
    City:
    Eastpointe
    State:
    Michigan
    -Return to Top-
    The crane is at my work, I work as a truck driver for a roll forming company. The work building has three long bays and cranes are used to move and load the machines with the metal stock for roll forming. There are 5 cranes in the building.
Share This Page
