- Jun 7, 2013
- 10,087
Be aware that aggressive grinding like that may cause microcracking of HSS, leading to breakdown of the cutting edge; if you see heat related color changes, it is not good.
OK, I'm still learning about making HSS tools, but have already learned that even with good grinding wheels (I have two dedicated grinders with various grits of Norton 38A and 32A wheels) that for some, there is a LOT of material to be removed. I've seen some YouTube guys making rough cuts with angle-grinders to get closer to the end shape with less grinding wheel time and wear and I happen to have a pretty decent old Ryobi 4" angle grinder sitting on the shelf collecting dust I could dedicate to this. So, my question, what is the ideal (might as well pick ideal(ish) since I'll be buying some wheels either way) type of wheel to use. Flat or dished/27? Grit? Material? I see some listed for Ferrous and Stainless. Is that good enough for HSS, or is there something better? Thanks in advance for any pointers.
This is where the belt grinders are really helpful. You can really hog material off with those things and a ceramic coarse belt. It's also easier to get a nice flat face. Other options can certainly work, but will likely be more time consuming for the larger material removal.
Thanks for the comments guys. I have 36, 60, 100 and 120 on 2 grinders (and rarely touch the 120), so I suppose I'm OK there. I like the belt sander idea. I have an old belt/disc combo sitting mostly unused in my secondary workshop (old 10x20 shed) which at the moment has no belt anyway, so I'll look into this ceramic belt idea and see how it works. Any suggested belt grit, given that this, and maybe still the angle grinder idea, will be for very rough/big cuts?
Thanks
