It sure is! I've just moved my machine tools into my semi-finished shop, still have two storage units full of general mechanic's and fabricator's tools, welding suff, etc. So the only chips in there are the ones that hitchhiked their way in.
@Larry$, yes, it is a Shars. I like it very much! With a small selection of wheels, I can do lathe bits, drill bits, spot drills, countersinks of multiple types, and a few other odds and ends. I do sharpen 2-4 flute end mills (faces and flutes) but this type of grinding setup sacrifices the center cutting ability of some mills. This is often the case, where the center cutting edges are obliterated with a gash cut or a centered face cut on the end mill. Center cutting is overrated anyway. The dressed quality of the wheel will determine how small of an EM you can cut and how close you can get to the center. Cheap wheels don't retain enough fine edge material to get close. A 1/2" end mill with only the outer half of the face cutting edges intact will still perform very well, you just
can't shouldn't plunge with it.
Edit: D-bits are easy to make with this grinder. You can custom grind any slot cutting profile you can imagine with a D-bit. I've been cutting little pieces of 1/2" O1 rod and making cool D-bits and countersinks as needed. Anything that saves ordering tools on a day off that I won't be able to use for a week.
