    Dismiss Notice
Mini Mill Power Feed For The Table
Discussion in 'MINI-LATHE & MINI-MILL INFORMATION' started by 3dshooter80, Dec 31, 2015.
  1. 3dshooter80
    3dshooter80 United States Master of Metal Malpractice Active Member
    451
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Here's a link to another short video from my little shop. I'll be doing a detail video on all the parts once I get the project completely finished. I'll also do a video on wiring the motor control & using an old computer power supply as a power source. Hope you enjoy this quickie.
    fixit, JamesSX2_7, ronboult and 7 others like this.
  2. Bamban
    Bamban United States Active User H-M Supporter-Premium
    181
    43
    City:
    Austin
    State:
    Texas
    -Return to Top-
    nicely done
    Wireaddict and 3dshooter80 like this.
  3. brav65
    brav65 Active User Active Member
    385
    63
    City:
    Phoenix
    State:
    Arizona
    -Return to Top-
    I like it !
    3dshooter80 likes this.
  4. David VanNorman
    David VanNorman United States H-M Supporter - Premium Content H-M Supporter-Premium
    130
    43
    City:
    Wind Ridge
    State:
    Pennsylvania
    -Return to Top-
    I like it too.
  5. easttex
    easttex United States Iron Registered Member
    13
    3
    City:
    Garrison, Texas
    State:
    Texas
    -Return to Top-
    Very clever
    Sent from my SAMSUNG-SM-G900A using Tapatalk
  6. T Bredehoft
    T Bredehoft Active User H-M Supporter-Premium
    1,161
    113
    Central Ohio
    City:
    St. Louisville
    State:
    Ohio
    -Return to Top-
    Nice clutch, why didn't I think of that.
  7. terrywerm
    terrywerm New Member Liaison Staff Member H-M Supporter-Premium
    674
    113
    Neither here nor there
    City:
    Jordan
    State:
    Minnesota
    -Return to Top-
    Very nice design, similar to something that I have been thinking about making for my Clausing 8520 mill. I will be looking forward to seeing more of the details on your project!
  8. T Bredehoft
    1,161
    113
    Central Ohio
    City:
    St. Louisville
    State:
    Ohio
    -Return to Top-
    How do I make/get the female hex? Perhaps 6 flat bottomed set screws?
    Edit: change fat to flat
  9. David VanNorman
    130
    43
    City:
    Wind Ridge
    State:
    Pennsylvania
    -Return to Top-
    It looks like a 3/8 or 1/2 " deep socket . It is being driven by a square drive. I'm most likely wrong.
    fixit and 3dshooter80 like this.
  10. terrywerm
    674
    113
    City:
    Jordan
    State:
    Minnesota
    -Return to Top-
    I was also thinking that it was a deep well socket, so maybe you're not so wrong after all.
  11. 3dshooter80
    451
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Yes, it's just a 9/16" deep socket. If I had it to do over I'd use a larger socket. The drive shaft has to be able to slide into the socket. I was able to drill this one out part the way, but had to do a lot of filing to get it to where the square shaft would pass through. Hopefully I'll get the detail video done tomorrow. I tore it down today & powder coated what shows & made a cover & clutch slide so I don't have to stick my fingers in it.
  12. MarkB
    MarkB United States Iron Registered Member
    2
    3
    City:
    Benton
    State:
    Kentucky
    -Return to Top-
    Good work!
  13. 3dshooter80
    451
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Here's the link to the detail video. Hope you enjoy.
  14. David VanNorman
    130
    43
    City:
    Wind Ridge
    State:
    Pennsylvania
    -Return to Top-
    Nice job make me thinks I'll make something like it . I like the socket clutch its simple and it works.
  15. Brentb1
    Brentb1 United States Iron Registered Member
    3
    3
    City:
    Fond du lac
    State:
    Wisconsin
    -Return to Top-
    I really enjoyed your video as you are very detailed and explained everything in a way that even someone that knows nothing about machining "me" can understand. I have a very similar mill "LMS 3990" and after seeing your video I am going to tackle this asap.
    brino likes this.
  16. 3dshooter80
    451
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Thanks for the compliments. I hope to get a couple more videos posted tomorrow on the power supply & motor control for the mill power feed.
    Upcoming videos will include a series on making a full set of archery stabilizers & mounts. Even those not interested in archery will hopefully enjoy the machining which will include everything from boring on the lathe to using a rotary table on the mill.
  17. cmonster6
    cmonster6 Swarf Registered Member
    1
    3
    City:
    Chester
    State:
    South Carolina
    -Return to Top-
    I'm building one similar to this using the same motor
  18. tincture500
    tincture500 United States Active Member Active Member
    11
    8
    City:
    louisville
    State:
    Kentucky
    -Return to Top-
    Like the design. Would like a few close-up pics of the drive engagement system and any experience improvements you would make if you did it again
  19. 3dshooter80
    451
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Did you watch the 2nd video linked in this thread? In it I do a break down explanation of the entire setup. The only thing I'd do different (which I plan to change tomorrow) is that the drive engagement knob (shown in 2nd video) need to be on the side instead of the top. I have to be careful now when I use the spin indexer to be sure its handle is clear of the knob.
    Other than that, I wouldn't change a thing - I am loving it & use it practically every time the table needs moving more than a few inches.
  20. tincture500
    11
    8
    City:
    louisville
    State:
    Kentucky
    -Return to Top-
    Any concern as to the feed not stopping ( get distracted ). May be a limit switch? Yes. I did watch both videos. Great work. Got the drive today awaiting the wiring info on the next video . awaiting the PWM speed controller. Thanks again. Tom
  21. 3dshooter80
    451
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Yep - I've got all the material purchased & ready to add some limit switches. Wiring them in will be quite simple, the biggest issue is where to mount them. I'll be making a follow up to my wiring video to show how to incorporate the limit switches so that if one is triggered the other will still have power.
  22. Zoltan
    Zoltan United States Active User Active Member
    12
    18
    City:
    Kensington
    State:
    Maryland
    -Return to Top-
    I used that same motor to make the power feed on my table. I wrote it up with some pictures here:
    http://benchtopmachineshop.blogspot.com/2014/06/mill-power-feed.html
    Since I wrote that blog entry I've moved the control box to the top left of the column, mounted the power supply to the back of the column with magnets, and made a small cover to keep chips off the motor's shaft.
  23. RCWorks
    RCWorks United States 5 Star Possum Chef Active Member
    30
    28
    At home
    City:
    Anadarko
    State:
    Oklahoma
    -Return to Top-
    I based mine on a 300 in/oz stepper, that means that my first axis is CNC ready.
    ronboult and 3dshooter80 like this.
  24. Sk8ter
    Sk8ter United States Active User Active Member
    6
    18
    City:
    portage
    State:
    Indiana
    -Return to Top-
    excellent job
  25. budbroruss
    budbroruss United States Swarf Registered Member
    1
    3
    City:
    Norco
    State:
    California
    -Return to Top-
    Nice Job!
  26. CarlosA
    CarlosA United States H-M Supporter - Premium Content H-M Supporter-Premium
    39
    18
    City:
    Portland
    State:
    Oregon
    -Return to Top-
    I will be watching this .. the micromark power feed does not work as expected. The slowest speed is too fast for slitting, or gear cutting, and it stalls very easily. I really didn`t want my mini mill to be a project, since I have some real projects that need to be done - but this is one I have to commit to.
  27. RCWorks
    30
    28
    At home
    City:
    Anadarko
    State:
    Oklahoma
    -Return to Top-
    Mine right now is at near 0 to 3.5 inches per minute.
    I need to step up the speed on the controller and go to 10 thread per inch leadscrews. that would over double me current speed.
    I figure on pulse rate alone I can go up to 5 IMP, anything I can get out of pulse rate will double on the leadscrew change.
  28. CarlosA
    39
    18
    City:
    Portland
    State:
    Oregon
    -Return to Top-
    Update...
    I upgraded to the .050 lead screws and the power feed works much better. I assume its because the motor can run at a higher RPM while giving me the slow speed I wanted with the geared down screws.
    rdean likes this.
  29. JamesSX2_7
    JamesSX2_7 Australia Iron Registered Member
    15
    3
    City:
    Melbourne
    State:
    Outside US / Canada
    -Return to Top-
    Hello,
    I wanted a power feed for my Mill too, and was most inspired by lpeedin's solution.
    I did go a little different, using a 24V straight geared motor.
    You can see the internals here (old photo - no engagement lever):
    The internals are a deep socket (9/16ths), with a sliding hex and "screwdriver tip" to engage the table screw.
    A large washer and pin provides a "slip ring" to pull and push the sliding part.
    The finished product:
    Have yet to finish the electronic end stops.
    I've created a short video of it running:
    James.
    David VanNorman and rdean like this.
  30. David VanNorman
    130
    43
    City:
    Wind Ridge
    State:
    Pennsylvania
    -Return to Top-
    That is nice neat job. You can be proud.
Share This Page
