    Dismiss Notice
Mini Mill Power Feed For The Table
Discussion in 'MINI-LATHE & MINI-MILL INFORMATION' started by 3dshooter80, Dec 31, 2015.
  1. JamesSX2_7
    JamesSX2_7 Australia Iron Registered Member
    15
    3
    City:
    Melbourne
    State:
    Outside US / Canada
    -Return to Top-
    Hi David,
    Thanks. I am also quite happy with how it turned out.
    Hopefully the end stops work well also. Bit concerned here as I am using magnetic sensors and steel chips/swarf may interfere. I can always go back to switches if needed.
    I'll update when I finally get around to finishing it.
    James.
  2. higgite
    higgite General Manger - Proofreading Dept. Active Member
    584
    93
    City:
    Houston
    State:
    Texas
    -Return to Top-
    Good job, James. I wish I had your skills and patience. I popped for the power feed with clutch from LMS. I'm quite happy with it, but wish it had a rapid traverse button. That is on my to do list.
    ETA: Also, good job by lspeedin. I forgot that he started this thread.
    Tom
  3. 3dshooter80
    3dshooter80 United States Master of Metal Malpractice Active Member
    453
    63
    City:
    Raleigh
    State:
    North Carolina
    -Return to Top-
    Great job James!
  4. JamesSX2_7
    15
    3
    City:
    Melbourne
    State:
    Outside US / Canada
    -Return to Top-
    Hello,
    Though I might give a brief update.
    I have now fitted "end stops" to the power feed.
    On someone elses suggestion, I used magnetic sensors (Hall effect sensors).
    I have mounted these in a plastic box on the saddle, and have moveable magnets on the table.
    I have placed the magnets in a plastic rod (white pieces), but have now bought some aluminium for a better finish.
    The steel blocks are held with a bolt, which can be loosened and slid along to where required.
    Seems to work very well, and is repeatable to within 0.02mm.
    It is impossible to set accurately though, as the sliding action is not too smooth.
    Big question is: will these work properly when covered in lots of steel chips?
    Haven't really used it enough yet to find out.
    It it works OK, I definitely like it better than having some sort of contact.
    James.
  5. David VanNorman
    David VanNorman United States H-M Supporter - Premium Content H-M Supporter-Premium
    130
    43
    City:
    Wind Ridge
    State:
    Pennsylvania
    -Return to Top-
    I like what you have done. Years ago I worked with mag operated switches. These was little contacts in a glass tube . They worked quite well. Hope you have good success with your set up.
  6. JamesSX2_7
    15
    3
    City:
    Melbourne
    State:
    Outside US / Canada
    -Return to Top-
    Hello,
    David, the contacts in glass tube are called reed switches. These were the "original" magnetic switch.
    Hall effect sensors are the electronic replacement. They are more sensitive and can switch bigger loads.
    I gave the end stops a bit of a work out yesterday.
    As I expected, lots of chips stuck to the magnets - but they kept operating.
    Forgot to check change in accuracy when covered with chips (concentrating on work!), but they DID stop the chuck hitting the tie downs in a tight setup.
    Other interesting side effect: when needed, I can hand crank PAST the magnet, and use power feed to continue on.
    I found this useful where I wanted to move well away from the cutter for measuring and adjusting the tie downs.
    Cannot easily do this with a mechanical switch.
    James.
    higgite likes this.
Share This Page
