- May 7, 2023
- 1,478
Congratulations, you have discovered spotting/Transfer screws.It worked! The Cone-Point Set Screws, when threaded into the bed mount and extended a little bit, worked like four spaced center punches to mark the steel plate for drill and tap locations. I decided to leave out the chip tray, as it would just impede brush & vac cleanup. It’s <1/2 degree off from level in the long direction of the ways and barely off perpendicular to the ways, so I didn’t shim before bolting the bed down.
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com
These things are invaluable and I have made my own on occasion. Now their so damn cheap I just hit up Azon whenever I need a set I don't have.
They're not quality, (I paid $7 for a set)but I also don't have to roll around the floor looking for the one I dropped from my expensive sets.
