- Dec 6, 2021
- 228
I went thru this a few years ago and was a little frustrated by all the vague descriptions and product codes. Measuring the spindle and buying from a vendor showing complete specs was the reassurance I needed.
For example, THIS listing on Amazon shows three different size choices – 80mm, 100mm and 125mm. Only the 80mm has the 55mm spindle recess to match my Harbor Freight 7x12. I wanted something bigger, so I knew I'd need a chuck and a 55mm adaptor plate.
As @DavidR8 (R8 the taper or R8 the Audi...?) mentioned above, LMS can definitely get you squared away. They've got a great info page too. But there are plenty of ebay sellers with the same chuck and adaptor plate. Just takes more time and of calipers to be sure you're buying the right stuff.
