- Feb 1, 2015
- 9,605
Jim, I just came up from playing with the new app. It works great! The only addition that I would want is for it to start the pot of coffee in the morning.Updated program uploaded.
The changes thus far:
Attached is the updated DC_Microscope2.zip. It is an installer package to install the program on your computer. This has been tested on WinXP, Win 7, and Win 8, installs and works fine. When installing, if it asks you if you want to keep your existing Quartz.dll file, YES, keep your existing file.
- Changeable line colors, can be changed on the fly. Better contrast on some backgrounds.
- Added Bulls Eye Function, up date time is a bit slow, working on it. Only works at 640x480 resolution
- Software movable Cross-hairs via scroll bars
I will try to implement anybody's requests, just ask. I'm having fun with this.
I like the scalable bullseye. I can see using it to find the center of a hole or circular boss. The movable crosshairs make a simple task of centering on the spindle axis. The two pictures are of scribed lines on a piece of aluminum. The aluminum was wet sanded with 2000 grit wet or dry paper. The camera lighting is turned way down to improve contrast, hence the odd color. The camera is set at maximum magnification.
The vertical line is 1.2 thousandths and the horizontal line is .9 thousandths in width. The second picture is taken with the camera rotated 180 deg. The smallest circle is about 1 thousandth in diameter. As you can see, the device is capable of placing the spindle location to a few ten-thousandths of an inch.
Well done!
Bob
