Hello Again!
Thanks, 4gsr for your link. That is actually the movie I referred to that I saw on youtube.
I have a short update now:
I have been able to restore the original "Drum Switch" and make it works again. I'm glad I will be able to use that just because it's so pretty
Now I have a lot of parts waiting for paint and so on, and the cables is in place, yet still not connected. The original electrical parts is in different states of refurbishment and I plan to have the electrical connections done by eastern.
I have a friend that is electrician, and he is amazed by the fact that all original electric switches is so sturdy and robust that they can be refurbished after all this year. That would never have been possible with modern electrical switches.
I have just opened them up (They are assembled with "normal" screws, of cource) Cleaned them and used a Dremel with steel brush on the BRASS contact points, Replaced a couple of rusted screws and some paint and polish.
I have started on the Apron to that needs a lot of work.
I was able to open up most of the lubricating tubes on the apron, but one is impossible to open, and another one I drilled a hole in, so I have to replace two of the aluminum tubes.
When I got the Apron clean, I saw some cracks around the feeding axel hole. I plan to weld that and redo the lubricating hole that passes through this to feed oil to the "mode change axel" I'l post an update to show the results of the fix
Please post any input you have on tools that is common on a lathe like this.
BR
