- Oct 27, 2013
- 124
Trying to keep this "in house", but the material supplied (3' bar stock) wont fit through the spindle. It's a simple shaft end bore, to receive a female spline receiver hacked out of a transmission and turned down to a diameter that fits in the shaft bore, one of my choosing. Retained by a spot of weld, a woodruff key and setscrews, or a spring clip, again lots of options. Plenty of latitude and loose tolerances. Not up for cutting the internal blind spline receiver directly in the shaft because the receiver part was supplied.
The new material is just a few thousands over my spindle bore. I knew that was a possibility, but this morning I find it wont fit.
suggestions?
clamp the stock to the cross slide and push it into a spinning bore bit? or turn the mill head 90 degrees and line bore with the milling machine (shaft is too long to mount vertically)? hand drill in a vise?
BTW the budget for this project is about $10 (ha)
I do have access to a bigger lathe but like I said I want to do it myself.
Thanks for your inputs in advance.
suggestions?
