- Mar 25, 2013
- 4,643
You could keep the Pb part simple. Print a source holder out of plastic per your design. Then use a 2 mm think Pb sheet disc on the back side and a short lead tube to line the center hole. You could make that all out of flat Pb sheet. No machining. The plastic would hold the sources in the correct geometry and you would minimize the Pb to where it is needed.
