- Dec 18, 2019
- 6,447
Yes, but there are limitations with boring as well. If the boring bar is narrow compared to the hole depth one can have some errors due to bar deflection. (I learned that the hard way.) Carbide bars deflect less than steel, but for length to width ratios greater than 6:1, even carbide deflects. 10:1 and higher ratios are tough. Long skinny precise holes are not easy. Possible with good techniques, but it takes a bit of skill.Reamers are good for their intended purpose but they have two limitations. First; They will only created the size hole they were made to create. And more importantly, they will follow the hole. Ream a crooked drilled hole and you'll get a crooked reamed hole. Only by boring can you make straight concentric hole that is any size you need it to be.
Need a precise hole, drill to remove the bulk, then bore. Possibly ream at the end. I have found that boring with a sharp insert (0.002" Nose radius) gives really nice precise results. I'm forever in gratitude for Mickey's tutorial on boring. Learned a whole lot from him. RIP.
