- Feb 1, 2015
- 9,605
For small holes, I use my pin gages. If you have a oversize and undersize set, you can come in to within about a half a thou. e.g, your shaft size is between ,2350" and .2354" by your measure and the standard over and under sizes would be .2348" , .2352", and .2358".
Barring that, prior to making the hole, I would turn a set of custom pins, one the exact size required and one or two smaller pins, perhaps a thou undersized for one and a half thou under for another.
I have made custom boring bars out of old drills or taps for holes as small as three mm.
