Making a Set of Mini Pallet Toe Clamps for the Milling Machine
Janderso
Jeff Anderson
H-M Platinum Supporter
Mar 26, 2018
8,412
I need clamps.
The mini pallet for the mill and rotary table are on my short list.
The video by Keith Rucker inspired me to use his dimensions and style.
I hesitated for days about which steel I should use. I decided on 4140HT.
I checked around different online sources and chose my friends at McMaster.
This piece is 1/2" X 1/4" X 18". It's precision ground, hardened 4140.
The price is $38 plus shipping = $51.
My question to you, should I use this beautiful piece of stock?
Is there a substitute you feel comfortable recommending?
I appreciate your ideas.
Use it. It'll make a quality clamp. You can always get another piece if needed.
McMaster-Carr has been getting a lot of my business lately, and they always come through.
If that's already hardened isn't going to be a bear to machine?
Ok, thanks jbobb,
I see people complaining about the quality of unknown steel from Ebay and scrap yards.
I get it, steel is expensive, what isn't these days.
Nah, I thought so too. John York, AKA benmychree convinced me to quit buying the annealed stuff. I've tried machining hardened 4140HT, HSS cuts it and of course carbide works just fine.
I don't think I've drilled and tapped it yet. Should be OK. It's not like tool steel. This is chrome moly.
I do wear my big boy pants when I work with this stuff though.
OK that's good to know as I would have never bought HT otherwise.
Thanks for the tip!
Just watch for any bending when you cut the slot. As small as these clamps are, it'll probably be minimal, but just keep an eye on them.
I've machine a ton of 4142HT. It's tough stuff, but not bad to work with.
I wasn't expecting stress. Good tip
i have made clamps form scrap to identified steels as well as aluminum
just about any steel would have sufficient mechanical properties to be used as a clamp
my favorite material is 303 for ease of machining and abundance in the form of scrap in my shop
aluminum has worked well too
