- Apr 30, 2015
- 11,307
Jim: those caps are pretty small and wouldn't have a large impact on the waveform. Actually as Pete mentioned, it might be better to have a voltage
suppressor (MOV) right across the chuck terminals- you could dispense with the 4 diode caps most likely. They won't protect the switch anyway.
Pete was also concerned about AC residue in the DC output causing heating- my feeling is the chuck is going to heat up anyway even if you fed it pure DC, so
I thought the small amount of AC harmonics wouldn't make much difference. I've never used an electromagnetic chuck so I'm kind of making educated guesses here
about the proper way to power it. Main thing would be to make sure the rectifier and switch don't get clobbered by the chuck voltage spikes.
Pete: I hear you about the SCR situation, that's a whole 'nuther level of complexity. Rick (I think) wants the minimum parts count that's reliable.
Rick: There should be a suppressor on the chuck terminals. Metal Oxide Varistor. I have a couple, I could send you one. They are about the size of a quarter with two wires coming out. It will limit the voltage spike to about 180 volts. Part number V130L20. Amazon may have them too.
Mark S.
Mark S.
