    Dismiss Notice
Magnetic Chuck Control Circuit Wanted
Discussion in 'ELECTRICAL ISSUES - POWER YOUR MACHINES & SHOP' started by MozamPete, Apr 4, 2017.
  1. markba633csi
    markba633csi United States Active Member Active Member
    234
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    The PTC (positive temperature coefficient) device is the same little gizmo that they used to control the degaussing coils around your color tv picture tube. It tapers the current down as it heats up. John H. and I (and others) were thinking it would give a better demag effect than just a shot of AC because if your shot happened to stop right on the peak of the AC sinewave- well you get the idea. Of course if you have a variac in the circuit you could just flip the switch to demag and turn the voltage down. Same effect.
    The MOV (metal oxide varistor) is a voltage clamp like a double zener diode. Protection for the bridge rectifier and toggle sw. from inductive kick from the chuck coil. Small 0.1uf cap also. Omit them if you dare LOL Someone else (Pete?) zapped a bridge already. But his setup was somewhat unusual.
    Extra filtering caps- optional as far as I'm concerned. Another part to dry out and fail someday. If you can get good results without it...Large high voltage electrolytics are always the weak link- and expensive. Use the smallest uf value you can.
    Mark
  2. markba633csi
    234
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Be careful out there everyone- don't do the 60 cycle shuffle unless you have a partner.
    MS
  3. Bob Korves
    Bob Korves H-M Supporter - Premium Content H-M Supporter-Premium
    2,884
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    I was studying this while you were writing, Mark. OK, I understand using the variac and dialing it down to demag, bypassing the rectifier. I like that idea, and have the stuff to do it.
    I thought that a fairly large cap was needed to smooth the DC ripple created by the rectifier. It sounds like I may be missing something here... My electronic knowledge leaves a lot to be desired.
  4. Rick Berk
    Rick Berk United States Active User Active Member
    66
    28
    City:
    Nashville
    State:
    Indiana
    -Return to Top-
    YES, I'm still here and learning, think I have located a variac, will know the details by Saturday.
  5. whitmore
    whitmore United States Active Member Active Member
    32
    18
    City:
    Shoreline
    State:
    Washington
    -Return to Top-
    A smoothing of the DC ripple is also accomplished by use of an inductor, like... the
    hulking electromagnet. It is so effective at smoothing current, in fact, that
    the switch and Variac windings are likely to get arc discharge damage, if the MOV is
    omitted from the circuit. A large capacitor would smooth low-frequency ripple,
    but a small one prevents RF switching hash (so the Variac adjustment doesn't
    put static onto every AM radio in the vicinity). An early schematic has small
    capacitors across every diode in the bridge rectifier (a sure sign that someone
    is a ham, IMHO).
    hman and JimDawson like this.
  6. markba633csi
    234
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    :D No, never keyed up, actually. A little shortwave listening only. One can only have so many hobbies LOL
    I think whitmore and I are on the same frequency. I didn't know if a big cap would be needed on the dc output so I didn't show one.
    If you do use a big filter cap be sure to hang it across the bridge rectifier output not the chuck terminals. You don't want to put AC on it. AC is ok for the little cap and the MOV.
    MS
    Bob Korves and whitmore like this.
  7. whitmore
    32
    18
    City:
    Shoreline
    State:
    Washington
    -Return to Top-
    The magnet, as inductor, takes the rectified AC and makes its RMS value
    (about 120V) average across the load. A big filter cap, takes the rectified AC
    and potentially makes the peak (170V) appear, on average, across the load. That
    exceeds the expected applied DC voltage... by too much. The filter capacitor
    is not particularly useful, unless the AC ripple on the inductor causes
    hum (in some way that disturbs the cut). If that were to be an issue,
    a stepdown transformer, or variac with a stop, would fix it, at some cost.
    The switching of a 170VDC power source is hard to accomplish: most
    switches cannot handle DC voltages that high. The DigiKey offerings top out
    at 125 VDC for toggle switches (but 277VAC if switching alternating current).
  8. MozamPete
    MozamPete South Africa Active User H-M Supporter-Premium
    682
    93
    City:
    Ladysmith
    State:
    Outside US / Canada
    -Return to Top-
    The inductance of the magnetic chuck will tend to smooth out and average the current flowing, not the voltage. Without a capacitor the voltage waveform will still be the same raw rectified AC voltage and you will still be exposing the coils to the 170V peak, just only for a short period 120 times a second (instead of continually if you had smoothing capacitor).
    This has been my main problem with trying to develop a transformerless design - and exasperated by the fact I'm starting with a 230V ac supply over here so have a potential 325V peak.
  9. markba633csi
    234
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Here's the proper switch
  10. whitmore
    32
    18
    City:
    Shoreline
    State:
    Washington
    -Return to Top-
    Yes, the current (which determines resistive heating) is limited by the 120V average
    if there's no big filter capacitor. Resistive heating, and overcurrent causing
    saturation effects, are things to avoid. Overvoltage, on the other hand... that's
    no problem for any reasonable wiring insulation: all the wiring in motors and
    such gets kilovolts applied for safety testing. The peak DC voltage doesn't
    threaten the electromagnet. The average voltage, though, does.
    A variant on a light dimmer (the kind of light dimmer that runs transformer-operated
    lights) can effectively lower average voltage, by switching the AC input. Another way
    to feed less voltage from a too-high-voltage input, is to use a ballast (like,
    the old-fashioned magnetic fluorescent ballasts) before the rectifier.
    One might build a decent 100V/1A current source by connecting AC through
    old-style magnetic fluorescent ballasts (one or more in parallel).
    Dimmers are, alas, likely to fail in full-brightness mode, so fuses are not
    optional if the dimmer is the only voltage limit.
  11. Bob Korves
    2,884
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    I already have, on hand, two variacs.
    The first one shows either:
    Input: 120V 50/60hz -- Output: 0-120v -- Amps 2.25 -- V.A. 270
    or
    Input: 120V 60hz -- Output 0-132V -- Amps 2.25 -- V.A. 297
    The second one:
    Input 120V 50/60hz
    Output: 0-140V KVA =1 (big mutha')
    I also have a 450V, 470 μF electrolytic cap, 105C
    I also have a drum switch and a more than capable rectifier bridge, and a bleed resistor...
    Whitmore and Mark, tell me where I might go next with this start...
  12. markba633csi
    234
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Bob what are the specs again on your mag chuck? (Input voltage and amps or watts)
    MS
  13. whitmore
    32
    18
    City:
    Shoreline
    State:
    Washington
    -Return to Top-
    Well, MozamPete says the 8x24 incher (192 square inches) takes 130W,
    so your 5x11 (55 square inches) ought to be comfortable with 38W.
    To start, get a fuse (1/2A, maybe less) and run the Variac output
    through the fuse into the rectifier. Check that the chuck terminals (there
    should be two, and a ground) don't have a short to ground, then
    connect the rectifier output to (1) a DC-voltmeter and (2) through a
    DC-ammeter, into the chuck. MOV at the chuck, if you have one.
    Start at something safe (20V?) on the variac, and note current and voltage readings,
    preferably on graph paper... take small steps (2 to 5V) and plot a few V-versus-I points,
    as you turn up the Variac.
    If the chuck starts to buzz, it's probably magnetically saturating (and further
    current increase is counterproductive). Note the variac reading, and DC voltage.
    If you get all the way to 120 on the Variac and the fuse hasn't blown, shut down.
    Now, look at the graph: if it's just a straight line, no problem. If it starts
    straight, and curves UP to higher current at some voltage, note the onset
    of that curve and subtract 10 percent. The upcurve happens when the magnet
    starts to saturate, you do NOT want that to happen in operation. It's
    equivalent to overloading a motor, which hums, heats, emits smoke...
    The ripple current after the rectifier will upswing sharply at saturation.
    Speaking of which, even if the fuse doesn't blow, if you smell something
    from the magnetic chuck, shut down. Obviously.
    The idea here, is just to get a current and voltage operating point.
    It would be great if you could put an AC ammeter in series with the DC
    ammeter: the AC ammeter will show a strong indication when magnetic
    saturation occurs, and the DC ammeter will tell you the operating current to stay well under.
    The AC ammeter will also jump every time you adjust the Variac.
    Ulma Doctor and Bob Korves like this.
  14. Bob Korves
    2,884
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    No tags. Resistance is 86 ohms across the the plug on the electrical cable. Everything is properly soldered in the chuck, so that number should be usable. I am sure it was meant to be fed 120VDC. I am guessing(!) that I would not want to run more than 120 watts (1 amp) to the chuck at 120VDC. The variacs will give me some wiggle room there...
    Ulma Doctor likes this.
  15. Bob Korves
    2,884
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Thanks, whitmore! That sounds like a very good way to test the chuck for how much power it can accommodate before it saturates. I will do that and report back, may take a while to find enough components to make a reasonably safe and worthwhile test run. The chuck body has no connection to the power wires, already tested...
  16. markba633csi
    234
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Sounds good. You don't HAVE to have an isolated supply to run your chuck, but it is safer from a shock hazard standpoint. Code would require it. But in your own
    house you can decide. Just make sure the chuck is well grounded whichever way you go.
    Cheers,
    MS
  17. Bob Korves
    2,884
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    I plan to change the cord to a three wire one, and ground to the chuck casing. The existing cord is at least 50 years old and is petrified anyway, but interestingly has no cracks or other issues, just very stiff. To hell with code, I do it to standards that are considered safe by those in the know... It is my tail that is on the line! Thanks!
  18. Bob Korves
    2,884
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    6x18" chucks typically draw about 100-120 watts, maximum.
  19. MozamPete
    682
    93
    City:
    Ladysmith
    State:
    Outside US / Canada
    -Return to Top-
    The chuck operating power should pretty much just be based on the DC resistance of the winding - in steady state operation on dc the inductance of the winding has no effect. So
    I = V/R and
    power = V²/R
    At 120Vdc and 86 ohms take would imply
    Current = 1.4 Amps
    Power = 167 Watts
    For comparison my 8" x 24" chuck name plate is 110Vdc, 1.3A, 144W and measuring the dc resistance of the chuck I get 92 Ohms.
    Bob Korves likes this.
  20. Bob Korves
    2,884
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Yes, and that sounds like too much power to me. Perhaps the voltage needs to be lower. The variac can do that easily. I like whitmore's method of testing for saturation, and I will do that.
    MozamPete likes this.
  21. skydownbr
    skydownbr Brazil Swarf Registered Member
    0
    1
    City:
    São Paulo
    State:
    Outside US / Canada
    -Return to Top-
    Hello to all.
    Enviado do meu iPad usando Tapatalk
  22. hman
    hman Active User H-M Supporter-Premium
    818
    113
    Tempe. AZ -and- Corvallis, OR
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    Hello to you, and welcome! Do you have a surface grinder?
  23. markba633csi
    234
    43
    City:
    Mountain View
    State:
    California
    -Return to Top-
    Hello Skydown
    MS
  24. awright
    awright United States Swarf Registered Member
    0
    1
    City:
    Oakland
    State:
    California
    -Return to Top-
  25. awright
    0
    1
    City:
    Oakland
    State:
    California
    -Return to Top-
    Whitmore, I'm not sure that you will get the desired indication of saturation in your graph if you are relying only on a DC ammeter. Granted, at saturation the incremental inductance disappears (or is reduced immediately or gradually, depending upon the hysteresis curve of the magnetic core), but because the DC current is determined only by the applied voltage and the DC resistance of the wire in the coil, not by the inductance, I would think the DC I/V curve would be immune to magnetic saturation effects. There would, however, be an indication on an AC ammeter looking at the ripple current if you are using an unfiltered, simple rectifier power supply. Having a sensitive tong type AC ammeter on the coil wire would give a useful indication of saturation, assuming an unfiltered supply. AC tong tools are relatively cheap these days.
    You do mention the desirability of having an AC ammeter in the circuit and the fact that it will indicate saturation, but I think an AC ammeter, not the DC I/V plot, should used as the primary indicator of magnetic saturation.
    However, I think the thermal dissipation of the coil would be the primary limiting factor on permissible applied DC voltage, probably long before saturation in a properly designed chuck. This is fairly difficult to evaluate non-destructively unless you have temperature sensor imbedded within the coil windings, something that you can only accomplish during winding of the coil. There would be an upward bend in the DC I/V curve due to heating of the wire, but thermal damage might occur before you saw the effect. One might get a useful indication of maximum permissible current by inserting a temperature sensor as deeply into the windings as possible (probably being only at the surface, depending upon the tidiness of the windings and the presence of any potting resin), and VERY GRADUALLY increasing the voltage/current while watching the temperature and feeling the surface of the chuck. By gradually, I mean over many hours, as the temperature will be maximum in the middle of the windings and it will take time for the surface to indicate possibly limiting temperature in the core.
    Be aware that I am not an electrical engineer (or even a magnetic or thermal engineer - or even a professional machinist).
  26. awright
    0
    1
    City:
    Oakland
    State:
    California
    -Return to Top-
    Recognizing that all power dissipation in the core is thermal, I think earlier discussions in this thread of scaling permissible power input from the dimensions of similar chucks with known ratings (and preferably, identical vintage since insulating materials have evolved) is a reasonable way to estimate permissible power dissipation in a chuck of unknown rating. Whether the scaling should be on surface area or volume is beyond me. Starting with a known standard of nearly identical dimensions would be ideal.
  27. whitmore
    32
    18
    City:
    Shoreline
    State:
    Washington
    -Return to Top-
    My concern was that AC ammeters are sometimes RMS, sometimes peak-and-correction, sometimes rectify-and-correction; it's usually unclear what exactly is being
    measured (a transformer-coupled oscilloscope would be ideal, though).
    Hopefully, all DC meters average over a few tenths of a second.
    If the magnet saturates, the current rise time gets faster, so the peak current
    happens sooner than when the full magnet inductance was present.
    Because inductive current is phase lagged, that means more power transferred
    to the load, and should cause a deviation on the I/V curve. I think.
    Maybe a true-power meter on the AC input is a cleaner choice?
  28. benmychree
    benmychree United States Active User H-M Supporter-Premium
    164
    43
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    Pardon, if this is not germane to the discussion, but I have a Brown & Sharpe Micromaster Surface grinder that came with a Neutrofier chuck control; when it degaussing feature is in use, one can see the grinding particles on the chuck poles lean one way, and the other way in a diminishing strength as the cycle does its thing; this suggests to me that the cycle is using direct current and diminishing the voltage as each reversal cycle is gone through, until there is no residual magnetism present in the chuck or work piece, at least not a discernible amount. From the noise it makes, it would seem that an electric motor drives a switch that does the current reversal. I also had a Chinese control on a 12 X 36 Thompson grinder; it was solid state and was tiny compared to the Neutrofier . It seemed to work the same way, by reversing DC input in a diminishing series of reversals. Both worked excellently.
  29. hman
    818
    113
    City:
    Tempe
    State:
    Arizona
    -Return to Top-
    That sure sounds like what a PTC would do in an AC circuit - reversals of diminishing strength - except that when using AC, the rate of reversal would be too fast to readily discern by watching the particles.
    I'm still waiting for the PTCs I ordered (slow boat from China), but as soon as I have them, I'll announce it here and offer them to anybody for just the cost of postage.
  30. Bob Korves
    2,884
    113
    USA
    City:
    Sacramento
    State:
    California
    -Return to Top-
    Hi, John, welcome to the thread! John (benmychree) is who I got the chuck we are talking about from, and a B & S surface grinder to go along with it. ;)
    Edit: John, I will see you Saturday morning at the mill.
Share This Page
