I'm afraid that those old Maglites are now dinosaurs. I let my Techshop membership lapse, so I don't have access to their big lathe anymore. Also, the other members would probably not like to see alkali, manganese dioxide and zinc powder spewed on the carriage and ways. Someone gave me two Maglites with batteries stuck in them. They are AA battery ones. You CANNOT use a dowel to push the batteries out of this model. Although the front cowl unscrews, there is a plastic flange that says "do not remove". If you remove it, there is a fragile socket and the switch spring pops out. You can get a steel rod through the opening but it will be too thin to do anything except punch holes in the top of the battery. The Internet says use penetrating oil. This did not work. It said thread and pull wood screws. This didn't work. Using a large drill didn't work. It just made a mess. A carefully made curved chisel which will peel the case (Duracell's have steel cases) off, but you have to be very careful to incrementally peel the corroded battery case without putting too much stress on the aluminum flashlight tube. I did not have the patience to even remove the first cell. The second one is exponentially tougher. Instead, I used a hacksaw to cut the case in half as near as possible to the head. You don't want to cut it right at the head, since you will need to use an aluminum collar to JB weld it together. It is very difficult to glue the flashlight back together again. If it is just glued back together, it will not conduct current properly from the negative pole of the battery to the lamp. A ring is made of copper wire to fit in the gap. This keeps the JB weld away from the inside. Anything on the inside will hang up the AA cells later on reassembly. They can end up getting stuck again. Glue the flashlight up with a half collar and don't put JB weld on the top or near the gap, lest it dribble down. Put batteries in the flashlight to keep it aligned. After it hardens in a couple of days, get the batteries out. This may be difficult, but it will be much more difficult if there if some of the epoxy dribbles in. Then, use a blob of solder in the gap of the copper ring to seal it. The solder will not stick, because the aluminum barrel will conduct the heat away, but it will improve the contact and fill the gap. Finally, put the top half of the collar on with JB weld. Due to flexing, and inaccuracy, the batteries will not fit. I tried using a homemade flat bladed reamer to fix this, but it doesn't work. These tools must be held firmly, and somehow it was cocking to an angle and raising a burr in the barrel before getting to the tight section. A lathe would have come in handy. A rat tail file will clear the barrel, but it will take hours. Eventually, the batteries will fit. The light works great now. It just has that ugly collar.
Somehow, I did not have the energy to fix the second light. It looks like it is corroded even worse that the first one. Interestingly enough, a cheap Chinese LED flashlight is much brighter with the same 2 AA power source. These Maglites are not really competitive, and neither are my repair skills. At least I succeeded, unlike all these Internet tips that I read.
