- Jul 14, 2017
- 2,451
I'm in a process of refreshing my car's engine, and one of the main things is dealing with the clutch and all the oil leaks. Bought a new pressure plate, clutch and release bearing but the flywheel is worn about 0,12-0,15mm and it seems to be uneven, no cracking or hot spots, so i wanted to try machining it on my lathe, but i've never turned an flywheel is it like turning brake discs any advice or thing to look for?
