I set out to make a new arbor for an old table saw I am currently refurbishing. I have done some between centers work but I haven't yet had to thread both ends of a shaft. I know a part can be removed from the lathe and then returned to the lathe with great accuracy. My question is once one end of the shaft is turned and threaded is it OK to remove it and swap end for end,, removing and reinstalling the dog end for end as well. Then go about finishing up the other end of the shaft. Am I thinking right here or am I headed for trouble. Any comments/suggestions appreciated.
Use a piece of soft sheet copper or aluminium between the the bottom of the set screw and the finished threads. That is how I did it. Good Luck.
