Some of that might be the table, some might be the ways. Need to check with a surface plate to tell.
Agreed, hard to tell for sure what is what. I took the whole table apart over the weekend and was surprised by the results with my micrometer. The table itself is within .0003" tolerance on thickness at each end, with the front being approx. .0008" thicker than the rear. Then, the middle is approx. .0015" thinner than at each end. Since I don't have a surface plate, all I can check is thickness, not actual straightness / flatness.
I then checked the saddle and it was within .0003" all the way around, but I discovered an issue here. After cleaning everything thoroughly, and lightly stoning the bottom of the saddle as the scraping pattern on there was very aggressive in a couple spots, I placed it on the base ways. Three of the four corners sit flat, with one corner, the front right when looking at the machine rising slightly. In fact, I can get a .006" feeler gauge under with essentially no rubbing. For some reason I can't find my .007", so I checked with an .oo8" and it goes in about 3/8". It appears that my saddle is slightly twisted / warped.
So, after finding that, I put it all back together. Then I took a 12" piece of 1.5" x .5" flat bar stock and put it in the vise and proceeded to make a skim cut on each side, just enough to clean up the face. I checked it after the cut and again, I can't check flatness, only relative thickness. I was within .0012" over 11.5", with approx. 7" of that being absolutely dead on, then all of the .0015" variance occuring over the last 4.5" or so. I think what is happening is that when the weight of the table shifts from the left side to the right side, the saddle is able to settle in the corner with the gap, causing the table to tilt slightly. I would definitely like to get the saddle surface ground to clean up the bottom face before messing with anything else.
