- Feb 17, 2013
- 4,406
3dshooter80 - You said, "I proceeded to flip the vise over on its ways, clamp it down lightly, just enough to hold it, and milled the bottom." I have the feeling the clamping itself might have caused some warpage.
Perhaps you could machine a "known square" block of steel, a little bit taller than the depth of the vise jaws, a couple inches wide (so it will span at least two of the T-slots on your mill table) and at least as long as the jaws. If possible, you could even have it surface ground. Secure the block to the mill, then invert the vise over the block and tighten it. This should guarantee that the vise ways are parallel to the table under "in use" conditions. Then do a careful job of milling the vise base surface.
