thanks!I’ll see if I can extract mine and I’ll measure it.
Other than diameter, I suspect it’s a non-critical dimension.
y'd think lead would get mashed.I thought I'd make one out of brassUnder certain set screws etc that went directly onto a threaded shaft my old Atlas 7b had lead shot under the screw. I thought it was kinda genius as it locked the shaft without marring it.
That’s why I thought it was genius. It’ll lock the shaft and not mar it. Brass will deform threads.y'd think lead would get mashed.I thought I'd make one out of brass
thanks allFor the pin, don't use steel - it will mar the shaft. Also, don't use lead - it will deform and flow into the threads so that you won't be able to get it out (without drilling). Aluminum may work, but I would be worried about mushrooming the head and getting it jammed into the threads like the lead. The original part was brass - it's hard enough to not deform, yet soft enough to not mar the shaft.
McMaster sells the knurled thumbscrew to replace the one you're missing. As for the size, it is a common thread (I don't remember the size - it was a #10 something), so just find a screw that fits and order that size.
thanks! - yeah, i'd get the steel one out of there...This is the original pin that I thought that I had lost. I made a new one out of steel. When I found this one I threw it in a drawer.
So, this one, I believe to be an original Southbend part. It's aluminum, it measures .126 dia × .242 long. I'm going to put this one where it belongs!
Really? Maybe there are some very hard brass alloys, but I've never heard of brass being harder than steel, even iron.That’s why I thought it was genius. It’ll lock the shaft and not mar it. Brass will deform threads.
Yes. This is all first hand observations. Of course brass is not harder than steel or iron. But i think you are thinking you have to smash a thread flat to foul it. On a typical 60deg thread it takes very little to smash the tip of the thread. If a small ding or piece of dirt will foul a thread...brass is nowhere near as soft as lead.Really? Maybe there are some very hard brass alloys, but I've never heard of brass being harder than steel, even iron.
