Looking for my perfect size hobby mill....
Yes, I ended up with the 728vt in my case... it was the right fit for me.
So how are you liking your new mill...?
I'm looking to maybe get the PM-728VT or the PM-25MV because both are in stock now, I was looking at the PM-727V over the 25MV but its out of stock and will arrive after my lathe by months, I need to mill the a T-Nut for the incoming lathe, after that I have no idea how much use ill get out of it...!
Do you think the Spec difference between the 728VT and 25MV Is worth the extra 1300.00 Bucks - Thanks Mike...
lol I'm thinking ill try and convince PM that I am buying it as an accessory to my lathe and see if I can get free shipping.. :)
Mr. Mike,
After adding a Digital Read Out (DRO) to it, it has proven to be a very solid working machine.
I would recommend it to anyone who has:
1. Space limitations
2. 120 VAC power limitations.
3. Wants a bit more working volume than many table top milling machines.
4. Needs a bit more precisions and repeatability than many table top milling machines.
Downside... does cost more.
Mr. Mike,
I like everything your saying, My issue is, and I could be wrong - for me it might be like a router, Sits on the shelf 95% of the time but absolutely priceless when you need it... I was in the works to get one in 2020 as you can see by this thread but then House hunting and covide got in the way... Poorboy had the PM-25MV for sale and I missed out on it. would have made a great starter mill I'm sure.
its just bad timing with a T-Nut Ill need soon, If it wasn't for that I would just wait till next year and get the PM-728VT or the 833TV I was considering, Edit: Guess i answered my own question - wait and get the better machine with DRO installed...
Thanks for the Info Sir, Glad to hear all is well the your mill..
Mike.
there is a PM25 for sale right in your town.
Unfortunately I missed out on it - Bad timing. Thanks for trying to give me a heads up on it...
I think Blondihacks recently upgraded from a PM25 to the 728, she has a video going over the differences. Short answer, the differences are mostly quality, the 728 can take a little bigger bites, and is a little tighter machine overall. The PM25 and 728 should be capable of doing the same work, the 728 will just be able to do it faster and maybe a little more accurately for the same effort.
Thanks Man ill go have a look see...
I always like blondihacks reviews, she says I should get the better VT mill.. But she didn't have much bad to say about the PM-25 either - so it's a good starter lathe. I've seen her make plenty on it in the past.
Edit: One thing I like about both the PM-25MV and PM-728VT Is there compact, available to ship so I could add one or the other now. But the quill travel is short on both machines. If I were to get one now it would make more sense to get a plain PM-25MV which is easier sell down the road if I decide I need a bigger machine like an PM-833T, unless all I really end up needing is the better PM-728VT then that would be a mistake..
Question: How big a deal is quill travel if that was a deciding factor..??? The PM-25 is 2" - PM728VT is 3" - PM-833T is 4.75 if the jump in quill travel from 3" to 4.75" isn't a giant leap in usability then I think the PM728VT is all I would need and can skip the PM-833T for the smaller foot print of the PM-728VT, and skip over the PM-25MV for the higher quality at the get go.
The only other thing I would like to do on a mill, at some point is maybe make some gears with a dividing head. If the PM-728VT is capable of that then I think It may be all I need for the long run..!
Thanks Mike.
Mike,
Once you have a mill you will find all kinds of cool stuff to make and repair. If you are already talking a starter mill that you can sell later. You should skip the little one and just buy a knee mill now, something like a PM-935TS 3 phase and add a VFD.....
Come on man you know you want one!!!!
Mike.
If the only reason to buy now is to make the T-Nut, why not just have one of us make it for you?
Other than that, my advice is to buy the largest, tightest/most rigid machine you can afford and have space for: otherwise you’ll regret it sooner rather than later. The step-up that Quinn made only cost her the mill itself as her other high cost investments (vise, rotary table, tooling, etc.) are a good fit for the new machine. If I were to upgrade to a Bench Mill (the largest I have room for and could maneuver into the shop) I’d have to include a lot of accessories, some immediately, others to take advantage of the improved capabilities.
