- Jun 12, 2014
- 4,821
I think we all have gone through a few machines and tools on our path to what we consider keepers. It was unclear as to the statement of the perfect starter mill as to your needs and the quality level you were looking at, but smaller mills do a very decent job of milling because a bench top design in a small configuration can be rigid enough, and for many they may be limited to 120VAC. The PM-928 is on the higher price point for a starter mill for most people, travel is very good, and with the base is around 450 lbs which is manageable for most people.
With regard to resale value, it may be debatable as to which holds better value, a knee or a bench-top. I will say that better built machinery will hold their value better than poorly made machinery. Some of the important characteristics of mills is the table travel, particularly the Y and also the Z (i.e. what will fit under the head). It sounds like you are divided between the something like the 935 and the 932, I personally feel on the latter you would be much better off with the 940. Main reason is you gain 4" of Y travel and 3" of Z travel. You are right up there with the pm-935 and a bit more Z travel. If you are looking for better quality, and you consider it affordable, then the PM-833 would fit the build.
I started with a bench mill comparable to the 932, and the biggest limitation was Y travel which was about 8.5" and you loose an inch with a DRO scale on the back. Put a bigger vice on it and you just can't get enough Y travel for milling something longer than 4". My biggest gripe was my first mill was marginal quality and some major faults, despite being quite expensive for a Chinese mainland built mill. There was also little to no post sales support and replacement parts took many months. I still could do very good and accurate work, so a story very similar to Bill's. I ended choosing a full size knee mill which is north of 2 tons and a beast to move even with a rolling base. Yes it is more rigid, it needs to be when you factor in the leverage distances going from the table to head in a long "C" shape. A bench-top can be very rigid with less mass. The PM-833 is close to 750 lbs without the base, the PM-932 is 850 lbs. Both are manageable with an engine hoist but still awkward.
If I was starting out, with what I know now after about 12 years of machining, in a bench-top the PM-833 would probably be my first choice, the PM-940 my second choice. If just making small parts and playing around, or even gunsmithing, I would be very happy with the PM-928VT. I also consider these bench-tops as movable should you need to relocate, full size mills that is a different story. I prefer a knee for other reasons, but I hope I never have to move it again.
