- Nov 17, 2018
- 41
I get 1.5879 mm shaft size, wire diameter 0.309 .. Thanks.
Thanks, I appreciate that.I took your photo and posted it on the Corvette Forum where I am active and asked there.....will let you know
I believe the carburetor clips are too thick.As mentioned by cathead above, old printers and the like have those, and other useful parts. If I were home I could send you a few. Also looks much like those found in carb kits. Mike
Yeah, I think that is what I am going to end up doing. Thanks again for all the replies, I really appreciate it.If you find a clip just a little too thick, it can be made thinner using a flat diamond hone. 400 grit works pretty well.
