- Jan 30, 2017
- 261
My model is the 513-504, the model # is wrong in my op. I would like a longer contact point to reach inside a barrel without having to pre drill the chamber.
That indicator with 2" tip from Long Island Indicators is exactly what I use to reach into a nascent barrel chamber and indicate the throat area. Depending on caliber you will probably still have to pre-bore or pre-drill as 2" won't get you to the throat by itself - you need to get some of the indicator body in there. I advocate boring at a taper matching your reamer body (but smaller, of course) - at that point you can dispense with bushings and the reamer can be held rigidly.My model is the 513-504, the model # is wrong in my op. I would like a longer contact point to reach inside a barrel without having to pre drill the chamber.
I have a Mitutoyo 513-403 indicator and I need a longer stem for it. I would like one that is 2” in length or close to it. I see some listed on Amazon, are they worth a try?
I like the indicator I have, I just want a longer stylus. I will check with Long Island for the stylus.Mitutoyo 513-415-10H Dial Test Indicator 1.0mm Range, 0.01mm Graduation *SHOWROOM*
Item Description Range: 1.0mm Graduation: 0.01mm Dial Reading: 0-50-0 Basic set- H Set (additional stem) Performs easy and accurate measurement of narrow or recessed areas, plus inside and outside diameters that dial indicators cannot access No-clutch structure for automatic reversal of...shop.idealprec.com
I know that it is "MM", but this is what i believe in the lines of what you are looking for yes?
I am new to chambering so I figured for my first one, I would let the reamer do all the cutting. I like the idea of removing the majority of material by boring and may try that.That indicator with 2" tip from Long Island Indicators is exactly what I use to reach into a nascent barrel chamber and indicate the throat area. Depending on caliber you will probably still have to pre-bore or pre-drill as 2" won't get you to the throat by itself - you need to get some of the indicator body in there. I advocate boring at a taper matching your reamer body (but smaller, of course) - at that point you can dispense with bushings and the reamer can be held rigidly.
GsT
The Mitutoyo 513-504 is calibrated for absolute reading accuracy with a tip that is exactly 0.60" long as illustrated in the extract from the Mitutoyo catalog page 16 shown below. I reiterate that if you put a longer probe on this indicator, it will no longer read accurately in an absolute sense. See the admonition from page 19 from the same Mitutoyo catalog. This is true for all brands of test indicators, not just Mitutoyo. If you want a test indicator with a longer probe that will accurately display absolute distances, you're going to need a different indicator, not just a longer probe.I like the indicator I have, I just want a longer stylus. I will check with Long Island for the stylus.
Interesting: I was surprised that Mitutoyo would use this method to remove the contact point, so I checked my DTI's (I have 8 that are functional and one that was dropped - thus the extras) and on all of them (with the exception of a $15 one), including the 513-118, there are flats on the contact point to facilitate using the supplied wrench to remove the point:
