- Dec 25, 2011
- 10,513
GG,
There must have been more to it than that. Note that in Jon's case, the banjo gear is compounded and the gearbox input gear is either flipped over or the spacer is put on before the gear (I can't quite tell whether the gear and spacer are one piece or two) so that the outer gear on the bottom of the tumbler drives the inner gear on the banjo and the outer gear on the banjo drives the gearbox gear. But in the photo that you posted, the small gear on the banjo is just a spacer. And the large gear is thus only an idler, like the FWD and REV tumbler gears.
When I bought my machine, there was a 48 tooth gear here, and the thread pitch was off. I had to change it to a 72 tooth gear to get the thread pitch to match the plate on the QCGB. Doesn't that mean that the number of teeth on this gear does matter?
GG
