- Dec 18, 2013
- 2,012
I'm on the edge of purchasing a gantry crane but can't seem to pull the trigger. Ahaha basically I'm looking for you people to talk me into it. I'm looking at the Harbor Freight 1 ton, $583 with a 20% off coupon so cost wise its not prohibitive.
I have an immediate use for a gantry crane, lifting a knee mill off its pallet and onto a stand. I have some other upcoming lifts and there are some tractor implements where the gantry crane would come in handy. But if I'm honest the crane would frequently gather dust which is probably why I'm on the fence.
First question - Who has/had a gantry crane and is it worth owning one? Pro's, con's?
I have an engine hoist...
Engine Hoist Pro's - It folds up into a 2x2 foot cube of shop space so its out of my way most of the time and on wheels should I need to move it around.
Engine Hoist Con's - The problem is the engine hoist is frequently FAIL at lifting things other than engines. You can't life a machine off a pallet due to the narrow legs. Yes you could re-inforce the pallet in the center, hack off the outsides with a sawsall, etc. etc. but that's not using the right tool for the job. I get highly annoyed when I know a job would be easy if only I had the right tool. It also has only one lift point which can get precarious when lifting a lathe or something that really needs two lifting points.
Gantry Crane Pro's - Bring on any width pallet that becomes a non-issue. I will equip with dual hoists so I'll be a lot more comfortable lifting just about anything with two lifting points. 2,000 lb capacity which would cover anything I would lift. R&R of tractor implements like my behemoth Landpride rototiller would be much easier. No limitations on the size of machine or stand the thing has about an 8 foot width. If I need to lift something onto a trailer or truck I could now do this.
Gantry Crane Con's - Its for lifting not for moving, while its on wheels you are not supposed to move it under load. But I tend to put everything on wheeled stands so not really an issue. Its BIG but I think I have that figured out.
For those of you like me who's shop is your average 3 car garage I think I have overcome the main issue with gantry cranes which is ceiling height. This HF gantry crane is about 100 inches high, my ceiling height varies from about 103 inches to 106 inches but there's all manner of shop lights and garage door brackets and stuff hanging down in the way. I thought it wasn't going to work until I got the idea of assembling the crane above the garage door tracks and opener in the 3rd bay.
I'll only be able to move the crane back and forth about 6 feet but it will clear everything and straddle the bay. One side of the crane will be up against a wall out of the way, the other side will be in the dead space between the 2nd and 3rd bay so mostly the crane will be out of my way. The Kubota tractor lives in this bay so its easy to park the tractor outside when I need to use the crane. How I'm going to fish that I beam up above the garage door tracts and opener during assembly...I'm still working on that.
